dsun01
Contributor
4 years agoJesd204B IP force F = 2 when use phy only wrapper
Dear Intel Support/Expert,
While I use Platform Designer to generate an Jesd204b IP. I need LMF = 4,16, 8. but once I change the Wrapper options to "Phy Only", after I click save, the LMF will be...
skbeh
Contributor
4 years agoAn update, this is not a bug. In fact F parameter only use in transport layer (MAC layer). When you select Phy-Only mode with Physical Layer only, the F parameter can be ignore not use.
