JAM/JBC file size increase from Quartus 16 to 20
- 6 years ago
You will need to use the command below to include the real-time ISP.
quartus_cpf -c <name>.pof <name>.jam -o background_programming=on
Thanks for providing me the file. In order to have smaller size, you need to enable the Real-Time ISP. In Quartus 16.1, it is automatically enable which cause the size to be smaller than 20.1.
The reason that the size is bigger when real-time ISP is not enabled is because that it will include programming the Max 10 before updating the flash while when you are using real-time ISP features, it is will directly programmed the flash without the need to program the Max 10 device.
John,
Thanks for the reply. I was able to create a smaller JAM file with the 20.1 programmer with the real-time ISP box checked.
The goal is to make this scripted with command lines. With the real-time ISP box checked, I saved the 20.1 CDF and then ran this from the command line
quartus_cpf -c v20_chain.cdf test20.jam
The test20.jam is still large. The real-time ISP information was not included in the CDF when running command line.
I was unable to find the parameter to make this work. how do I save the smaller JAM file from the command line?
