CBlow
6 years agoJAM/JBC file size increase from Quartus 16 to 20
A 10M04SCE144I7N design compiled in Quartus 16.1 generates JAM and JBC files that are 178KB and 357KB respectively.
When the same design is compiled in Quartus 20.1, the JAM and JBC files ...
- 6 years ago
You will need to use the command below to include the real-time ISP.
quartus_cpf -c <name>.pof <name>.jam -o background_programming=on
JohnT_Altera
6 years agoHi,
From my investigation on the jam file generated, it looks like there is additional features added into the JAM file generated which causes the file to be bigger. May I know if you enable the real-time ISP when you are using Quartus 20.1 to generate the JAM file? The reason is that I do not observed this features enabled.
