JayHarikumaran
4 years agoJAM Player exit code 10 Device Programming Failure
We have ported the JAM player onto an embedded processor. I can see the status is JBIC_SUCESS but the exit code says Device programming Failure. The FPGA is a MAX10 (10M08SC169I7G) device a...
NurAiman_M_Intel
4 years agoHi,
Apologize for the delay in response.
- Can you show me how did you generate the JAM? Show the setting when generating this file.
- Can you share the picture on how you do the programming?
Aiman
- JayHarikumaran4 years ago
Hi Aiman,
Apologies for the delayed response. I had some access issues to the community forum.
I have attached the settings. The Max 10 JTAG chain is connected to GPIO of our embedded mcu. We ported the jam player to the cpu.
We generate the JAM file and then convert the JAM file to JBC format using the jbc.exe using
"jbc -f2 -u xxx.jam xxx.jbc"Are the above options correct to use? We convert the jbc file to a C file with the entire buffer.
Jay
