JAM Player exit code 10 Device Programming Failure
Please see AN425 page 5.
Aiman
Hi Aiman,
I checked the page 5 you mentioned.
https://www.intel.com/content/www/us/en/docs/programmable/683089/current/generating-byte-code-jam-stapl-files.html
I have also attached the options I saw from the programmer when generating the jam file. The ISP clamp is turned off by default and I checked to make sure the ISP option is unchecked in the programmer options. I have attached the screen shots below.
It is not clear for me how to disable the ISP option. We have an MCU which is used to program the MAX 10 on the board. The JAM player is ported to that MCU to run the update.
Do I change the ISP mode from a quartus option in the .jam file generation or do i need to change anything in the jam player to send that command? For eg: in the jbi_execute function?
Thanks in advance for your help.
Jay
