JayHarikumaran
4 years agoJAM Player exit code 10 Device Programming Failure
We have ported the JAM player onto an embedded processor. I can see the status is JBIC_SUCESS but the exit code says Device programming Failure. The FPGA is a MAX10 (10M08SC169I7G) device a...
ak6dn
4 years agoWell, you have the source code, right? Where in the source code is the exit code 10 generated, for what cases?
- JayHarikumaran4 years ago
I can the exit code 10 is set in case 0x25
case 0x25: /* EXIT */
IF_CHECK_STACK(1)
*exit_code = (int) stack[--stack_ptr];
done = 1;
break;
How or why it gets here is harder to find out as the stack array is modified in many of the case statements which go to 0x80
