JAM 2.5 Player for Max 10 FPGA (10M08SAM153) on Intel Aero Compute Board fails to program/erase
After several discussion and investigation with internal team, it seems like the programming failure is due to the JAM file itself. The reason you obtained 0xFF is because the FPGA is blank. I think there is no failure on hardware.
A quick check with you, are you programing the correct JAM from correct directory? I check with the documentation, seems like the JAM file is aerofc_compute_board_only_fpga.jam and it is located in etc/ instead of etc/fpga
Thank You
- LostCompass5 years ago
Hi, Thank you for following up on this issue. Its very important for my research and so I really appreciate you getting back to me.
To answer your question, yes indeed. I am pretty sure the jam file is not the issue since I have a spare Aero Compute Board and programming the FPGA on that with the same Jam file gives no problems.
Could it be that the FPGA can brick some other way? e.g. if in any one of the program-erase cycles, the process was interrupted via a Ctrl+C command by mistake or if the JAM file's configuration was for a different FPGA board type? Going through all the online documentation, tells me that in such cases the programming would fail but would yield a success the next time a jam file with the correct configuration is used that matches the FPGA hardware spec. But in my case it doesn't at all yield a successful programming cycle even when I use a verified jam file provided by Intel: aerofc_compute_board_only_fpga.jam
