LostCompass
6 years agoJAM 2.5 Player for Max 10 FPGA (10M08SAM153) on Intel Aero Compute Board fails to program/erase
I have tried all possible ways to flash the MAX 10 FPGA on Intel Aero compute board using the default embedded JAM Player 2.5 that comes preinstalled on Intel aero-linux operating system. Im follow...
YuanLi_S_Intel
6 years agoThis is weird. So is the MAX10 working as intended after the first configuration?
LostCompass
6 years agoIt worked fine for the first 2 configurations. Then it just started failing. Also when I query the FPGA through the following command on the Intel-Poky linux:
aero-get-version.py
It gives me back 0xFF for the FPGA version. Whereas before it was 0xa1.
Using spi_dev to read an FPGA GPIO register (address:0x49) via the SPI bus also returns 0xFF everytime. So it appears the registers are reset to all 1s somehow.
