Issues with updating Arria10 PAC for AFU
- 5 years ago
I was finally able to update this using super-rsu after completely shutting off power to the server (cold reboot):
[]$ super-rsu --log-level trace /usr/share/opae/a10-gx-pac/super-rsu/base/rsu-09c4.json [2020-12-28 16:33:37,086] [DEBUG ] [MainThread ] - found fpga objects: ['/sys/class/fpga/intel-fpga-dev.0'] [2020-12-28 16:33:37,088] [DEBUG ] [MainThread ] - found device at 0000:3d:00.0 -tree is [pci_address(0000:3a:00.0), pci_id(0x8086, 0x2030)] [pci_address(0000:3b:00.0), pci_id(0x10b5, 0x8747)] [pci_address(0000:3c:08.0), pci_id(0x10b5, 0x8747)] [pci_address(0000:3d:00.0), pci_id(0x8086, 0x09c4)] [pci_address(0000:3c:10.0), pci_id(0x10b5, 0x8747)] [pci_address(0000:3e:00.0), pci_id(0x198a, 0x385c)] [2020-12-28 16:33:37,096] [WARNING ] [MainThread ] - Update starting. Please do not interrupt. [2020-12-28 16:33:37,097] [DEBUG ] [MainThread ] - [3d:00.0] version (0x0124000200000367) up to date for sr [2020-12-28 16:33:37,098] [DEBUG ] [MainThread ] - bmc_fw is being force flashed [2020-12-28 16:33:37,098] [DEBUG ] [MainThread ] - bmc_fw versions not equal (system:0x0000000000026889 != manifest:0x0000000000026895) [2020-12-28 16:33:37,098] [DEBUG ] [MainThread ] - bmc_fw versions not equal (system:0x0000000000026889 != manifest:0x0000000000026895) [2020-12-28 16:33:37,099] [DEBUG ] [MainThread ] - [3d:00.0] update timeout set to: 1200.0 [2020-12-28 16:33:37,099] [DEBUG ] [3d:00.0 ] - update of board at [pci_address(0000:3d:00.0), pci_id(0x8086, 0x09c4)] started [2020-12-28 16:33:37,099] [DEBUG ] [MainThread ] - max timeout set to: 0:20:00 [2020-12-28 16:33:37,100] [DEBUG ] [3d:00.0 ] - starting task: fpgasupdate /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4_bootloader-26895-fw_Release.bin 0000:3d:00.0 [2020-12-28 16:33:37,222] [WARNING ] Update starting. Please do not interrupt. [2020-12-28 16:33:37,223] [INFO ] updating from file /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4_bootloader-26895-fw_Release.bin with size 38016 [2020-12-28 16:33:37,331] [INFO ] writing to staging area [2020-12-28 16:34:36,173] [DEBUG ] [MainThread ] - waiting (0:19:00.927721) for threads: 3d:00.0 [2020-12-28 16:34:36,674] [DEBUG ] [MainThread ] - waiting (0:19:00.426487) for threads: 3d:00.0 (100%) [____________________] [38016/38016 bytes][Time:0:01:34.404933] [2020-12-28 16:35:11,747] [INFO ] applying update to 0000:3d:00.0 (100%) [____________________][Time:0:00:08.010363] [2020-12-28 16:35:19,757] [INFO ] update of 0000:3d:00.0 complete [2020-12-28 16:35:19,758] [INFO ] Secure update OK [2020-12-28 16:35:19,758] [INFO ] Total time: 0:01:42.536032 [2020-12-28 16:35:19,809] [DEBUG ] [3d:00.0 ] - task completed in 0:01:42.707920 [2020-12-28 16:35:19,809] [DEBUG ] [3d:00.0 ] - starting task: fpgasupdate /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4-26895-fw_Release.bin 0000:3d:00.0 [2020-12-28 16:35:19,932] [WARNING ] Update starting. Please do not interrupt. [2020-12-28 16:35:19,934] [INFO ] updating from file /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4-26895-fw_Release.bin with size 244864 [2020-12-28 16:35:20,039] [INFO ] writing to staging area (100%) [____________________] [244864/244864 bytes][Time:0:00:01.575939] [2020-12-28 16:35:21,626] [INFO ] applying update to 0000:3d:00.0 [2020-12-28 16:35:36,247] [DEBUG ] [MainThread ] - waiting (0:18:00.853465) for threads: 3d:00.0 [2020-12-28 16:35:36,748] [DEBUG ] [MainThread ] - waiting (0:18:00.352268) for threads: 3d:00.0 (100%) [____________________][Time:0:00:43.055355] [2020-12-28 16:36:04,681] [INFO ] update of 0000:3d:00.0 complete [2020-12-28 16:36:04,682] [INFO ] Secure update OK [2020-12-28 16:36:04,682] [INFO ] Total time: 0:00:44.749368 [2020-12-28 16:36:04,702] [DEBUG ] [3d:00.0 ] - task completed in 0:00:44.892688 [2020-12-28 16:36:05,283] [INFO ] [MainThread ] - 1 board updated. A power-cycle is required. [2020-12-28 16:36:05,284] [INFO ] [MainThread ] - super_rsu.pyc completed in: 0:02:28.187105 [2020-12-28 16:36:05,284] [INFO ] [MainThread ] - super-rsu exiting with code '0' #Check the fme with fpgainfo to make sure it is updated []$ fpgainfo fme Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEB00000 PCIe s:b:d:f : 0000:3D:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : userI'm not totally sure why the fpga-otsu command would not originally complete (and then finally completed), but my best guess is that using a slightly different kernel minor version or that restarting the server with cold reboot (powering off the server) helps to reinitialize the FPGA state and devices under /sys/. Note that warm reboots (normal power-cycle) may be causing some weirdness with the FPGA device initialization, which is why I've recommended cold reboots (turning off power completely for 20-30 seconds).
For the original issue with super-rsu my suggested solution is the following:
1) Follow the instructions to run fpga-otsu on pg. 40 of the AFU Quick Start Guide. If it fails, power the server off completely for ~30 seconds (cold reboot), power on, initialize the AFU devstack (`. /opt/inteldevstack/init_env.sh`) and rerun the command until it succeeds.
2) Once fpga-otsu completes, perform a cold reboot again. This command should probably replace Step 2 on pg. 41 that originally suggests to "2. Power cycle the server." which can mean either a warm or cold reboot.
3) Check that the ifpga_sec_mgr module is properly loaded correctly and that the ifpga_sec_mgr device exists. If it does not exist, try a cold reboot and check each time after initializing the AFU devstack.
`ls /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/ifpga_sec_mgr/
ifpga_sec0`4) If this device exists, then the super-rsu command should complete successfully (or at least fail elsewhere).
Hi, Young
Can you point me to the document and page you follow for installation ?
Eric
- jyoung5 years ago
Hi @EricMunYew_C_Intel - we are using the AFU Getting Started Guide (UG 20166). I'm not sure if the process has changed with recent OPAE announcements in November, to be honest.
@JohnT_Intel- apologies for the long delay. The student working on this claimed 1 of the boards in "server3" was working ok for his designs. Server2 we've never been able to get working.
Server2 still can't be upgraded to a newer firmware version.
[server2]$sudo fpgainfo fme Board Management Controller, microcontroller FW version 26889 Last Power Down Cause: POK_CORE Last Reset Cause: External reset Power-on-reset //****** FME ******// Object Id : 0xEC00000 PCIe s:b:d:f : 0000:01:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x123000200000185 Bitstream Version : 1.2.3 Pr Interface Id : 69528db6-eb31-577a-8c36-68f9faa081f6 Boot Page : userServer3 shows the correct bitstream version
[server3]$sudo fpgainfo fme Board Management Controller, microcontroller FW version 26889 Last Power Down Cause: POK_CORE Last Reset Cause: External reset Power-on-reset //****** FME ******// Object Id : 0xEC00000 PCIe s:b:d:f : 0000:89:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : user- jyoung5 years ago
I was reviewing my last post and noticed that the FW version on our "working" server, server3, was not yet updated to 26895. I reran the OTSU and super-rsu process
[server3$]fpgainfo fme Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEC00000 PCIe s:b:d:f : 0000:89:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : userHowever, the non-working server still won't run the OTSU update. I have also checked that the pacd service is not running (it's not enabled currently on either server). I've attached the debug output for the OTSU update command.
server2:~# systemctl stop pacd Failed to stop pacd.service: Unit pacd.service not loaded. root@server2:~# systemctl status pacd.service Unit pacd.service could not be found. root@server2:~# fpgaotsu --log-level debug /usr/share/opae/a10*/fpgaotsu/base/otsu-09C4.json [2020-11-24 13:22:04,809] [DEBUG ] [MainThread] found fpga objects: ['/sys/class/fpga/intel-fpga-dev.0'] [2020-11-24 13:22:04,810] [DEBUG ] [MainThread] found device at 0000:01:00.0 -tree is [pci_address(0000:00:1c.0), pci_id(0x8086, 0xa190)] [pci_address(0000:01:00.0), pci_id(0x8086, 0x09c4)] [2020-11-24 13:22:04,810] [DEBUG ] [MainThread] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/spi*/spi_master/spi*/spi*" [2020-11-24 13:22:04,810] [DEBUG ] [MainThread] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/ifpga_sec_mgr/ifpga_sec*" [2020-11-24 13:22:04,810] [INFO ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:01:00.0 is not secure. [2020-11-24 13:22:04,819] [WARNING ] [MainThread] Update starting. Please do not interrupt. [2020-11-24 13:22:04,820] [INFO ] [0000:01:00.0] Updating Intel PAC with Intel Arria 10 GX FPGA : 0000:01:00.0 [2020-11-24 13:22:04,820] [DEBUG ] [0000:01:00.0] could not find: "/sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/spi*/spi_master/spi*/spi*" [2020-11-24 13:22:04,822] [INFO ] [0000:01:00.0] Erasing flash@0x7fd0000 for 196608 bytes [2020-11-24 13:22:04,822] [DEBUG ] [0000:01:00.0] erasing 196608 bytes starting at 0x07fd0000 [2020-11-24 13:22:05,023] [INFO ] [0000:01:00.0] Writing flash@0x7ff0000 for 104 bytes (RushCreek_Release_key_blk2) [2020-11-24 13:22:05,023] [DEBUG ] [0000:01:00.0] (100%) [____________________] [104/104 bytes][Time:0:00:00.000055] [2020-11-24 13:22:05,025] [INFO ] [0000:01:00.0] Reading flash@0x7ff0000 for 104 bytes for verification [2020-11-24 13:22:05,025] [DEBUG ] [0000:01:00.0] copying 104 bytes from mtd device: /dev/mtd0 [2020-11-24 13:22:05,031] [DEBUG ] [0000:01:00.0] (100%) [____________________] [104/104 bytes][Time:0:00:00.005958] [2020-11-24 13:22:05,032] [INFO ] [0000:01:00.0] Verified flash@0x7ff0000 for 104 bytes (RushCreek_Release_key_blk2) [2020-11-24 13:22:05,032] [INFO ] [0000:01:00.0] Erasing flash@0x1800000 for 41943040 bytes [2020-11-24 13:22:05,032] [DEBUG ] [0000:01:00.0] erasing 41943040 bytes starting at 0x01800000 [2020-11-24 13:22:15,753] [ERROR ] [0000:01:00.0] [Errno 110] Connection timed out Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaotsu.py", line 509, in process_flash_item self.erase(flash, mtd_dev) File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaotsu.py", line 317, in erase (erase_end + 1) - erase_start) File "/usr/lib/python2.7/dist-packages/opae/admin/utils/mtd.py", line 149, in erase fcntl.ioctl(fp.fileno(), self.IOCTL_MTD_MEMERASE, iodata) IOError: [Errno 110] Connection timed out [2020-11-24 13:22:15,764] [INFO ] [MainThread] Total time: 0:00:10.944948 [2020-11-24 13:22:15,765] [ERROR ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:01:00.0: [Errno 110] Connection timed out [2020-11-24 13:22:15,765] [ERROR ] [MainThread] One-Time Secure Update failed
