Issues using IOWR for SPI communications
- 3 years ago
Thank you.
Kelly Jialin, GOH
Could you kindly check the SPI REGISTER enum is written correctly instead of writing to the register manually. As you can also use altera's driver to communicate with the register.
Here is the example test code using the SPI core: https://www.intel.com/content/www/us/en/docs/programmable/683130/22-1/example-test-code.html
Thank you.
Kelly
