Issues using IOWR for SPI communications
I am having difficulty using the IOWR and IORD functions in NIOS II.
We have a ENUM like below:
#define BASE 0x80
typedef enum SPI_REGISTERS_tag
READ_REG_5_E = 0x00,
WRITE_REG_0_E = 0x01,
SPI_STATUS_WORD = 0x02,
SPI_CONTROL_WORD = 0x03
} SPI_REGISTERS;
For SPI communication to send data we need to write 0x80 at I/O address 0x8C
When we use the below statement it works fine:
*(U32*)0x8C = 0x80;
But with below code the objective is not met:
IOWR(BASE, SPI_CONTROL_WORD, 0x80);
Which translates to below code:
__builtin_stwio (((void *)(((alt_u8*)(0x80)) + (((SPI_CONTROL_WORD)) * (32/8)))), (0x80));
When I read back the value written using above statement for address 8C I get value 0x10?
We tried to use IOWR32_DRIECT() but still the same issue. We verified the assembly instruction and they differend in stw / stwio instruction note that we are using data cache:
*(U32*)0x8C = 0x80;
00C02304 movi r3,0x8C ; r3,140
00802004 movi r2,0x80 ; r2,128
18800015 stw r2,0x0(r3) ; r2,0(r3)
18800035 stwio r2,0x0(r3) ; r2,0(r3)
I also tried making the CACHE size to 0 but no success.
What wrong am I doing and fix required to achieve the objective?
Thank you.
Kelly Jialin, GOH
- KellyJialin_Goh
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Kelly Jialin, GOH
- PrakashPrasad
The issue turned out that we needed to flush the CACHE. I do not have the underlying code but flushing the value worked for me.
Thanks for all your help
- KellyJialin_Goh
Thank you.
Kelly Jialin, GOH
- KellyJialin_Goh
Any updates from your end from your end? Is the feedback provided useful? You may check the SPI base offset address whether it is correct.
Thank you.
Kelly
- KellyJialin_Goh
Could you kindly check the SPI REGISTER enum is written correctly instead of writing to the register manually. As you can also use altera's driver to communicate with the register.
Here is the example test code using the SPI core: https://www.intel.com/content/www/us/en/docs/programmable/683130/22-1/example-test-code.html
Thank you.
Kelly
- PrakashPrasad
Thanks for valid information - unfortunately it seems that our code base build did not include the required .c files.
Hence I am only left with the assembly instruction way - please let me know if there is any alternative mechanism if any
Thanks in advance
- KellyJialin_Goh
Kelly
- KellyJialin_Goh
One more thing to check is that after adding in your .h header file, is the c code file present ? As the error message indicates that the c code file is missing and not added.
Looking forward to hearing from you.
Thank you.
Kelly
- KellyJialin_Goh
You may have a look at additional information of this HAL API function for your usage: https://www.intel.com/content/www/us/en/docs/programmable/683282/current/alt-dcache-flush-all.html
Thank you.
Kelly
- KellyJialin_Goh
Greetings and welcome to Intel's forum.
May I know if you have include the header file <sys/alt_cache.h> so that the function alt_dcache_flush_all() can be called?
Hope to hear on your response.
Thank you.
Kelly Jialin, GOH
- PrakashPrasad
Thanks for the update - I added the header file and the alt_dcache_flush_all() API call in my code but during compilation I get error like:-
undefined reference to `alt_dcache_flush_all'
Do we need to add any specific library for same to resolve?
