8 years agoIssues Downloading Cyclone V Image to EPCS Device / RBF-JIC File Discrepancies
I'm having a difficult time with programming a portion of my EPCQ configuration device and having things behave as I expect on the subsequent power cycle. Any insight into what I'm doing wrong would...
8 years agoHi
Are you using .rpd file for Active Serial configuration scheme? User should not be using .rbf file for Active Serial configuration scheme. The .rpd file should have the same content as the .jic file. For more information check below links https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05182010_4.html http://quartushelp.altera.com/16.1/index.htm#mapidtopics/mwh1465406445129.htm Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
