KMico
7 years agoIssue with Micron MT25QL128 booting up at cold
I have a design that has a Cyclone V FPGA using a MT25QL128 quad-spi config flash. The config flash is having an issue booting up at cold (< -10 deg C) when utilizing Active Serial x4. If I create a ...
YuanLi_S_Intel
7 years agoHi Kyle,
I have checked the Cyclone V that you are using, seems like it is able to work at low temperature up to -40 C. Can you please check if the micron is able to work at low temperature?
Also, may i know how many unit is impacted? or it is just 1? If it so, i would encourage to do ERMA.
YL
