Matt1
6 years agoissue with IOPLL in quartus prime 18.0
error reported as Error(19252): None of the output clocks of IOPLL "pll_test|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst" are connected. Please use at least one All the pins in the PLL componen...
Rahul_S_Intel1
6 years agoHi Matt,
The above issue is due to the quartus optimization of the logic, make sure that when using the ip to connect to the logics
- Matt16 years ago
thanks RSree for your reply.
I want to keep the component in my design and i dont want to connect to any logic,(that is,connect the output to a signal)
I hope it was possible in megafunction.
can you suggest some possibility.
