ChandanSuthar
6 years agoIssue while using HSMC as single-ended GPIO
Hello everyone
I'm using Altera Stratix - IV (EP4SGX230KF40C2) and intend to use the HSMC ports as GPIOs; specifically, for receiving the single-ended digital outputs from external ADCs on to the F...
EngWei_O_Intel
6 years agoHi ChandanSuthar
Thanks for your inquiry.
It depends on what IO standard does the ADC uses, and check if which bank the HSMC pin is connected to, if the Vccio of that bank supports the IO standard that the ADC uses, then they can be used.
Eng Wei
- EngWei_O_Intel5 years ago
Hi ChandanSuthar
We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
