16 years agoisolation for Altera programmer
I have a situation where the ground of my FPGA circuit is at a potential a few volts below the earth ground. Normally, if my FPGA and PC grounds are the same, I use a USB Blaster to program either th...
16 years agoA follow-up in case anybody is interested:
The Keterex USB-150 isolator works with the USB-Blaster. That device is spec'd to work only for USB "Full Speed" so this confirms the above responses.
