16 years agoisolation for Altera programmer
I have a situation where the ground of my FPGA circuit is at a potential a few volts below the earth ground. Normally, if my FPGA and PC grounds are the same, I use a USB Blaster to program either th...
16 years agoUSB Blaster uses standard full speed. Commercially available isolators should generally work.
On the JTAG side, the total round-trip delay (the critical path is TCK + TDO) must not exceed 80 ns, including two isolator instances and all driver and target chip delays. Thus rather fast couplers are needed. NVE IL71x are e.g. good for this application. A DC-DC converter is required to feed the target power supply to the USB Blaster's JTAG drivers - or a modification of the USB Blaster to supply it internally with fixed 3.3 V. I append a circuit of a 3.3V JTAG isolator that has served it's purpose in power electronics applications.
