is there the same silicon chip used in different housings
if one can buy the same size in different housings, will the chip be the same for the housing with lowest and highest Pin Count?
Would e.g. same silicon chip being housed in 484Pin BGA (i.e. having xyz IO) used in the 240Pin QFP with "just" not connected IO cells due to lower pin count?
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
- WZ2
Hi there,
WZ
