16 years agois there some 7 segment code example
hello is there some 7 segment code sample for ciclone 2 fpga ?
16 years agoPlease explain better what you need.
If you simply want to connect a 7 segment display to a binary counter, here is some VHDL code.
entity decoder7seg is
port (DIGIT : in std_logic_vector(3 downto 0);
SEG : out std_logic_vector(6 downto 0) );
end entity decoder7seg;
architecture decoder7seg_a of decoder7seg is
begin
--decode : process DIGIT is
SEG <= "0111111" when DIGIT="00000" else -- 0
"0000110" when DIGIT="0001" else -- 1
"1011011" when DIGIT="0010" else -- 2
"1001111" when DIGIT="0011" else -- 3
"1100110" when DIGIT="0100" else -- 4
"1101101" when DIGIT="0101" else -- 5
"1111101" when DIGIT="0110" else -- 6
"0000111" when DIGIT="0111" else -- 7
"1111111" when DIGIT="1000" else -- 8
"1101111" when DIGIT="1001" else -- 9
"1110111" when DIGIT="1010" else -- A
"1111100" when DIGIT="1011" else -- b
"0111001" when DIGIT="1100" else -- C
"1011110" when DIGIT="1101" else -- d
"1111001" when DIGIT="1110" else -- E
"1110001" when DIGIT="1111" else -- F
"0000000";
end architecture decoder7seg_a;
I don't describe connection between SEG bits and each display segments, since it should be easy to understand. Cris
