Is there further documentation on electrical characteristics of GXE transceivers used in E-tiles?
- 6 years ago
As I understand it, you are looking for specific specs ie capacitive load of the E-Tile XCVR pins and voltage level at RX ADC. For your information, as I look into the device datasheet, I am unable to locate any specific info on this. Currently, the datasheet is the only document for specs reference. Sorry for the inconvenience.
By the way, mind share with me the specific reason you are looking for the capacitive load of the pins ie for simulation purpose?
Thank you.
thanks for your update. As I understand it, you would like to inquire for the S10 E-Tile IBIS-AMI models. For your information, this information is provided to customer through IPS and with NDA in place. Just would like to check with you if you are aware of you local FAE or sales? You may get in touch with them on the IBIS-AMI model request. They should be able to work on the IPS flow for the file request.
Thank you.
- mkurzmann6 years ago
No, I do not know how to locate my local FAE or sales. How can I look up this information?
