Is there further documentation on electrical characteristics of GXE transceivers used in E-tiles?
- 6 years ago
As I understand it, you are looking for specific specs ie capacitive load of the E-Tile XCVR pins and voltage level at RX ADC. For your information, as I look into the device datasheet, I am unable to locate any specific info on this. Currently, the datasheet is the only document for specs reference. Sorry for the inconvenience.
By the way, mind share with me the specific reason you are looking for the capacitive load of the pins ie for simulation purpose?
Thank you.
Thank you.
- mkurzmann6 years ago
Thank you for your response.
I am looking for information regarding the capacitive load as I wanted to interface to a device via a cable assembly and am trying to figure out whether repeaters or retimers will be necessary on the signal path to maintain signal integrity.
Please let me add another piece to the question: Are there IBIS-AMI models available for customers in order to do channel simulation? I have found simulation results in AN835 https://www.intel.com/content/www/us/en/programmable/documentation/qjz1512512364550.html#wov1513107044515 but no related models in the resource section.
Cheers!
