12 years agoIs there any way to pre-load the Altera DDR3 (Uniphy) Memory Model?
Hi - to speed simulation, I'd like to pre-load the memory with data. There is surprisingly little documentation that I can find on the Altera Memory Model. Can anyone point me in the right directio...
12 years agoHi,
In case you're using off-chip memory and use Qsys you can use the External memory BFM discussed in Section V, chapter 3 of http://www.altera.com/literature/ug/ug_avalon_verification_ip.pdf. I understand that this is not what you asked for in the first place, documentation about the Altera Memory Models does indeed seem to be sparse... Cheers
