13 years agoIs there any document describing Altera Jtag components?
I find the component **_jtag in the library of Quartus, but cann't find detailed information about it.
The component is as below: component cyclone_jtag generic ( lpm_hint : string := "UNUSED"; lpm_type : string := "cyclone_jtag" ); port( clkdruser : out std_logic; ntrst : in std_logic := '0'; runidleuser : out std_logic; shiftuser : out std_logic; tck : in std_logic := '0'; tckutap : out std_logic; tdi : in std_logic := '0'; tdiutap : out std_logic; tdo : out std_logic; tdouser : in std_logic := '0'; tdoutap : in std_logic := '0'; tms : in std_logic := '0'; tmsutap : out std_logic; updateuser : out std_logic; usr1user : out std_logic ); end component;7 Replies
--- Quote Start --- Thanks for your advice. --- Quote End --- No problem. Hopefully it saved you some time. If you have a specific use-case that you do not want to discuss here, eg., a code example, just send me an email directly (to my forum name). Cheers, Dave - Altera_Forum
I see.
Thanks for your advice. Regards, Ryan - Altera_Forum
--- Quote Start --- My application is the first one. --- Quote End --- Then Altera will only support you if you use the SLD_Virtual_JTAG component. --- Quote Start --- Did you mean users can not use "cyclone_jtag" component in the "..\quartus\libraries\vhdl\cyclone_components.vhd"? What's this "cyclone_jtag" component for? --- Quote End --- It might be used when creating a simulation model. You might also find that if you use a MegaWizard to instantiate a JTAG component that this component is internally used. However, direct instantiation of the SLD_Virtual_JTAG should give you identical (or at least very similar) control. Keep in mind that any VHDL you can read in the atoms files or the low-level device files *is not real*, i.e., you will never get to see what Altera synthesis files look like. That is all part of their secret-sauce. If you are trying to create a vendor-neutral interface to your JTAG components, then you need to go through the SLD_Vitual_JTAG components for Altera, and the BSCAN components for Xilinx, and I forget what the JTAG components are called for Lattice. Bottom line is you have to use a vendor specific component to access your vendor neutral code. Cheers, Dave - Altera_Forum
Did you mean users can not use "cyclone_jtag" component in the "..\quartus\libraries\vhdl\cyclone_components.vhd"? What's this "cyclone_jtag" component for? Regards, Ryan - Altera_Forum
--- Quote Start --- I am trying to use these family_jtags to connect our JTAG-supported soft modules(inside FPGAs), so we can access both vendor's JTAG component and our soft modules by software. Your notes give the information about virtual jtag, but the component "family_jtag" is the primitive. What I really want to use is the primitive. Is there any detailed information about this component's pinout? --- Quote End --- The *only* supported JTAG component is the SLD_Virtual_JTAG component. Altera's JTAG-to-Avalon components are internally constructed from a component that is essentially identical to this part too, eg., see these notes: http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf I'm still not quite clear on your requirements: 1) If you have a JTAG-like component that you want to access, you need to connect it via the SLD_Virtual_JTAG component. 2) If you have a component with registers, then you can access it via a JTAG-to-Avalon-MM bridge, just provide your component with an Avalon-MM slave interface. Can you please clarify. Cheers, Dave - Altera_Forum
Hi, Dave,
I am trying to use these family_jtags to connect our JTAG-supported soft modules(inside FPGAs), so we can access both vendor's JTAG component and our soft modules by software. Your notes give the information about virtual jtag, but the component "family_jtag" is the primitive. What I really want to use is the primitive. Is there any detailed information about this component's pinout? - Altera_Forum
The JTAG components are not well documented.
Here's my notes: http://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf You'll find that the cyclone_jtag is a device-specific implementation of some other generic JTAG component. What were you trying to implement? Cheers, Dave
