13 years agoIs there any document describing Altera Jtag components?
I find the component **_jtag in the library of Quartus, but cann't find detailed information about it. The component is as below: component cyclone_jtag generic ( lpm_hint : string...
13 years ago --- Quote Start --- My application is the first one. --- Quote End --- Then Altera will only support you if you use the SLD_Virtual_JTAG component. --- Quote Start --- Did you mean users can not use "cyclone_jtag" component in the "..\quartus\libraries\vhdl\cyclone_components.vhd"? What's this "cyclone_jtag" component for? --- Quote End --- It might be used when creating a simulation model. You might also find that if you use a MegaWizard to instantiate a JTAG component that this component is internally used. However, direct instantiation of the SLD_Virtual_JTAG should give you identical (or at least very similar) control. Keep in mind that any VHDL you can read in the atoms files or the low-level device files *is not real*, i.e., you will never get to see what Altera synthesis files look like. That is all part of their secret-sauce. If you are trying to create a vendor-neutral interface to your JTAG components, then you need to go through the SLD_Vitual_JTAG components for Altera, and the BSCAN components for Xilinx, and I forget what the JTAG components are called for Lattice. Bottom line is you have to use a vendor specific component to access your vendor neutral code. Cheers, Dave
