13 years agoIs there any document describing Altera Jtag components?
I find the component **_jtag in the library of Quartus, but cann't find detailed information about it. The component is as below: component cyclone_jtag generic ( lpm_hint : string...
13 years ago --- Quote Start --- I am trying to use these family_jtags to connect our JTAG-supported soft modules(inside FPGAs), so we can access both vendor's JTAG component and our soft modules by software. Your notes give the information about virtual jtag, but the component "family_jtag" is the primitive. What I really want to use is the primitive. Is there any detailed information about this component's pinout? --- Quote End --- The *only* supported JTAG component is the SLD_Virtual_JTAG component. Altera's JTAG-to-Avalon components are internally constructed from a component that is essentially identical to this part too, eg., see these notes: http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf I'm still not quite clear on your requirements: 1) If you have a JTAG-like component that you want to access, you need to connect it via the SLD_Virtual_JTAG component. 2) If you have a component with registers, then you can access it via a JTAG-to-Avalon-MM bridge, just provide your component with an Avalon-MM slave interface. Can you please clarify. Cheers, Dave
