12 years agoIs there any difference on DE4 board schematics between EP4SGX230KF and EP4SGX530KH?
I use the Stratix IV GX DE4 board, EP4SGX530KH40C2N fpga. I downloaded DE4_Install file on terasic. and there is a schematics of EP4SGX230KF40 I'm not sure about whether i can use this schematic on my EP4SGX530KH40C2N fpga. Is there any difference on schematics between DE4 board EP4SGX230KF40 and EP4SGX530KH40C2N?? Anybody who knows this, please help.2 Replies
The two boards are identical. I can give you some top-level example designs if you like.
Which version of Quartus are you using? I'll check that the example designs synthesize correctly. Cheers, Dave - Altera_Forum
--- Quote Start --- The two boards are identical. I can give you some top-level example designs if you like. Which version of Quartus are you using? I'll check that the example designs synthesize correctly. Cheers, Dave --- Quote End --- Thank you, Dave! I have some version of Quartus, 12.1, 13.0 and 14.0. If you have, please give me some examples about PCIe. Thanks :)
