16 years agoIs there a tool can generate waveforms from a text file
Dear all:
I am a novice. I use Forte to simulate some circuit models. The results denote the changes of signals by text. But I want the diagram which is more visible. Could someone tell me that is there a tool can do this? I can do some modifications on the text format if necessary. Thank you in advance.:)3 Replies
also modelsim can import Value change dump (VCD) files.
OK, thanks a lot.
search for gtkwave, it can do what you want, but you might have to change the text.
