gyuunyuu
Contributor
6 years agoIs there a standard way to store and retrieve "build information" of an FPGA design?
The following things are to be stored inside the FPGA: 1. Build date 2. Build time 3. Build top level file name 4. Build repository commit number for version controlled design 5. Submodule repos...
KhaiChein_Y_Intel
6 years agoHi,
qsys-generate is the TCL command that is used to generate the Qsys system. The software will regenerate the system even if you did not specify the command, provided you have added the .qsys file (not .qip) in the project.
