15 years agoIs there a signal from the ALTGX indicating the CDR is locked to the incoming data?
I need to know when the ALTGX's CDR is locked to the incoming data rate, but there doesn't seem to be a signal that serves this purpose. The rx-freqlocked is almost this signal, but not quite. ...
14 years agoThe answer is that there is no signal that indicates the receiver is locked to the incoming data stream. The signal "rxfreq_locked" indicates that the CDR is currently in lock-to-data mode. This is why manually asserting ltd will force this signal high. The only way to somewhat determine if the receiver is locked is to monitor the "rxfreq_locked" signal. If it remains asserted for a period of time (meaning the receiver remains in lock-to-data mode) then you can assume it is locked. If the signal deassert, you are not locked to the incoming data stream.
