KLohr
6 years agoIs it possible to simulate with the ModelSim Altera Edition (free) the On-Chip Flash Intel FPGA IP? I am able to simulate with questa-sim at my work place, but I get an error (below) when trying to simulate at home with the free version.
I'm using Quartus Prime Lite Edition 18.1 with the On-Chip Flash Intel FPGA IP. When I use the Tools/Run Simulation Tool/RTL Simulation I get an error: "# ** Error: (vsim-3033) C:/DigitalAir/CCIOEXP...
KLohr
6 years agoThanks for your patience Anand. I unzipped the file and ran the commands exactly as you have indicated with the same result: "# ** Error: (vsim-3033) c:/testfpga/flash_ip/synthesis/submodules/altera_onchip_flash.v(309): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.# Time: 0 ps Iteration: 0 Instance: /testbench/testfpga/flash_ip/onchip_flash_0 File: c:/testfpga/flash_ip/synthesis/submodules/altera_onchip_flash.v"
It also couldn't find dual_cfg_ip. The transcript is attached.
