Is it possible to configure Agilex-F P-Tile to have a PCIe Gen4 X4 EP port and a Gen4 X4 RP port?
- 6 years ago
Thanks for the helps.
I misunderstood your words of "only assign". Actually you mean "only connect", which makes sense for me. I will try it soon, and right now I am struggling on generating the RP IP.
Xiao
Hi Xiao,
It looks fine to me. You may start with a simple design and only assign the pin for port 4-7 and determine whether there is any abnormality from the Quartus compilation.
Regards -SK
Let me try it out later. But currently I stuck in generating the RP IP.
Does the routing tool consider it as an error for unassigned ports at lane#0-3 and lane#8-15? Actually the PHY locations for these unused lanes are fixed and the pad location can be assigned automatically by the routing tool (other company's fpga tool does like this). I worry that the RP port on lane#0-3 could be active still?
Xiao
