17 years ago
is it possible...?
...to use the jtag/usb-blaster to send data from the pc to the development board to control it (i.e using the hyperterminal or something like that to send control characters)? :confused:
    libusb permits using USB port from user space. This is a low level library, in that case, you must have on your development kit a hardware or firmware that implements an USB device. In this case you can't use the USB blaster connector, an additional one is needed.
    thanks for your answer and the example, parrado...
    i'm gonna take a look on that demo to see how it works the .dll, and how to use in quartus/nios projects. anyway, i've searched for some info on google and i found a c library for usb communications, libusb. do you know about this library? is it possible to use it instead the jtag_atlantic? any kind of information/orientation would be really helpfull to me.
    thanks in advance.
    Use SOPC Builder to add a JTAGUART to your architecture. In this way you can communicate via your USB link. The easiest is to use a Nios-II processor, but you can also directly communicate with your slave devices.
