Is it not possible to use all clock outputs of an Arria 10 IOPLL
I checked the report (congestion summary in Fitter report) and tried to remove all clocks.
But the error remains. It seems the fitter do not recognize my assignments.
assignment:
-name GLOBAL_SIGNAL OFF -to "deserializer:DESER|sen_pll:SENPLL_6|sen_pll_altera_iopll_181_qprrpya:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[3]~CLKENA0"
fitter:
Info (175026): Source: auto-promoted clock driver deserializer:DESER|sen_pll:SENPLL_6|sen_pll_altera_iopll_181_qprrpya:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[3]~CLKENA0
What can I do more?
Hi Jen
Are you able to share you sample design?
Eng Wei
- Jens5 years ago
Hi Eng Wei
I made a stripped down version of this project so you can check the quartus errors.
Jens
- EngWei_O_Intel5 years ago
Hi Jen
Have you try to use ALTCLKCTRL IP to route your clock to regional clock?
Eng Wei
- Jens5 years ago
Hi Eng Wei,
no. It seems to me that Quartus have no problem to route the global clock to regional clock. But there are not enough ressorces to connect all PLL outputs in that region.
Jens
Hi Jens
Sorry for late response as I have just back from the extended holiday. Let me take a look on the attached design.
Eng Wei
