TNaka61
7 years agoIs "Cyclone 10 LP" slower than "Cyclone IV E" ?
I tested according to the same source code (VHDL) shown below. The reported delay was almost the same... but "Cyclone 10 LP" gave the following timing error @300MHz clock. Is my setting incomplete...
KennyT_altera
7 years agoeach device had their own speed grade. Each of their own benefits and depends on your needs.
You can refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51002.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51002.pdf
Cyclone E usually is used for Optimized for lowest system cost and power for a wide spectrum of general logic and DSP applications.
Intel® Cyclone® 10 LP FPGAs usually used for optimized for low static power, low-cost applications, such as I/O expansion, sensor fusion, motor/motion control, chip-to-chip bridging, and control.
