13 years agoIs CONF_DONE read by the FPGA?
Hi All, I'm debugging a board with a Cyclone IV device where the CONF_DONE pin was inadvertently left floating. The FPGA configures fine over JTAG but when configuring from EPCS it reads the w...
13 years agoOkay, it would appear that the option works as expected. I created a JIC file from the SOF and checked the "Disable AS mode CONF_DONE error check" box. Programmed the EPCS64 with the JIC and the FPGA configured correctly at power up. Hurrah.
Here's where I'm stuck now. I normally create the EPCS image with sof2flash followed by elf2flash with the --after option. The programming file converter will generate lots of useful files, but not a srec flash file. Looking at what sof2flash does with the --verbose flag, it generates a POF from the SOF with quartus_cpf and then generates a RPD from the POF with quartus_cpf. Then the info spewed out by --verbose stops. What is the step to create a flash SREC file from the RPD? Thanks, Mark.
