ip-make-simscript not generating script for Riviera
- 4 years ago
Can I check what is written in the spd_list.txt?
I think your script is not direct to the .spd file.
I try to create a simple project with PLL IP, generate HDL for Riviera only, run Analysis and synthesis.
In GUI, Generate Simulator Setup Script for IP works.
In command, it works with the rivierapro_setup.tcl generated.
ip-make-simscript --spd=C:\quartus_project\quartus_pro\simulation_test\pll\pll.spd --output-directory=C:\quartus_project\quartus_pro\simulation_test\pll\simulation --simulator=RIVIERA
You can try a simpler project to test the flow whether it works.
Have you try to generate the simulation file in the Platform Designer ? There is a ton of similar errors complaining in the log file.
2022.07.15.16:50:03 Error: File /tmp/workspace/MCD4_UVM_Simulation/default/tao-2/modules/demux_emif/cores/ip/amr_ac_emif_afifo_pl/amr_ac_emif_afifo_pl_dc_fifo_0/sim/common/modelsim_files.tcl not found. Please generate simulation files for system file amr_ac_emif_afifo_pl_dc_fifo_0.ip before generating simulation scripts.
