SK_VA's avatar
SK_VA
6 years ago
IO_OBUF Placement and IC delay in timing path
Is there anyways we can constrain the placement of IO_OBUF so that it is closer to the pad.
How can we reduce the IC delay in the timing path?
  • SK_VA's avatar
    SK_VA
    Thanks for reply. nand_dq_out is bidirectional.Let me try adding register.
  • SK_VA's avatar
    SK_VA
    I tried this solution by registering the output.But timing is still failing.
    • SK_VA's avatar
      SK_VA
      I am still not able to meet the timing with the suggested options.When I add additional registers,the interface itself is not working.
      6.105 is not IC delay its cell delay.
  • KennyT_altera's avatar
    KennyT_altera
    can u share the screenshot?
    1) the resource property editor that show that the register is inside the DDIO location?
    2) Timing analyzer report showing the violation
    3) the latest .sdc files showing how frequency that you use for that pin
    4) what IO standard that you are using
