- SK_VA
Thanks for reply. nand_dq_out is bidirectional.Let me try adding register.
- SK_VA
I tried this solution by registering the output.But timing is still failing.
- KennyT_altera
can u send out the same screenshot?
- KennyT_altera
any update?
- SK_VA
I am still not able to meet the timing with the suggested options.When I add additional registers,the interface itself is not working.
6.105 is not IC delay its cell delay.
- KennyT_altera
can u share the screenshot?
1) the resource property editor that show that the register is inside the DDIO location?
2) Timing analyzer report showing the violation
3) the latest .sdc files showing how frequency that you use for that pin
4) what IO standard that you are using
- KennyT_altera
Any Update?
