IDeyn
Contributor
7 years agoI/O D1/D3 delay values higher than needed.
I have a problem, and it could be described like this: there is PHY - to FPGA (Cyclone V) RGMII interface, receive side (for FPGA). Namely I have 125 MHZ, DDR, I use center-aligned mode, I exploi...
AnandRaj_S_Intel
7 years agoHi Ivan,
That's how tool behaves.
Design may/may not meet timing requirements. We have to set it manually.
Anand
- IDeyn7 years ago
Contributor
Hi Anand!
Sorry for my persistence, but if it is like you said, what is the driving signal for the engine to automatically set I/O delay elements values?
I mean, the engine should be guided by something, so why not to be guided by a positive slack as an aim?
Because it explicitly does not set them randomly, as we demonstrated the timing results are quite stable.
Ivan
