I/O Bank choice for 64 bit wide EMIF on Cyclone 10 (GX)
- 4 years ago
Hi KeeganJ,
Thank you for submitting you question in Intel Community,
I'm Adzim, application engineer will assist you in this thread.
You have right understanding on IO banks usage.
I also would like to suggest to use "Option One" because you can use termination on LVDS IO bank.
The VCCIO for DDR3 protocol must be driven at 1.5V.
You need to make sure the voltage is correct for every IO banks that have been used for EMIF IP.
The option below is correct.
- Option One: 2A (data), 2J (addr/command), 2K (data)
Adzim
