14 years agoInvalid output from MM--> ST (SGDMA)
Hi, Im wondering if anyone experience this problem before. i was transferring content in my SDRAM to a DCFIFO outside of SOPC using SGDMA. The SDRAM content is all zeros. but after the SGDMA...
14 years agoThe problem was solved.. it turns out to be a "loose" wire between FPGA and acq board that is causing this problem.
