14 years agoInvalid output from MM--> ST (SGDMA)
Hi, Im wondering if anyone experience this problem before. i was transferring content in my SDRAM to a DCFIFO outside of SOPC using SGDMA. The SDRAM content is all zeros. but after the SGDMA...
14 years agoNo I haven't faced a problem like that... Are you sure that the RAM contents is 0? Especially if you have a data cache, ensure that it is flushed before you start the transfer.
Is the DMA reading at the correct address? Use a Signaltap instance to monitor what the SGDMA is doing.
