17 years agoInterNiche Superloop example for 9.0sp1
I have recently posted this superloop example to the Nios Wiki, please follow the link below. superloop simple socket server plus (http://www.nioswiki.com/exampledesigns/superloopsimplesocketse...
15 years ago --- Quote Start --- Hi rfrazer, I was trying to compile the project you uploaded i.e. superloop_sss_plus_3c120_marvell_90sp1 in Nios II command shell version 9.1. As expected, it fails. It passes in 9.0. Is this design version dependent? What should I modify if I wish to run on v9.1 or v10.0 and above? Thanks. Caridee --- Quote End --- Hi, I am facing the same problem. I'd like to run the superloop simple socket server design example on version 10.0sp1. In addition to, can any one help me on running it on NIOS II for eclipse. Thanks & Regards
