15 years agoInternal Clock HELP
Helloo.. I had a project to do on an Altera Cyclone II board, it's a Digital Calendar. I've completed it successfully but I have a problem with the clock, I have a 27MHz and 50MHz internal clo...
15 years agoThen as suggested by others, previous posts, you can divide down MHz to Hz. Then use it has global clock. At Hz frequency, PLL would not work.
