15 years agoInternal Clock HELP
Helloo..
I had a project to do on an Altera Cyclone II board, it's a Digital Calendar. I've completed it successfully but I have a problem with the clock, I have a 27MHz and 50MHz internal clocks, and I need to make the calendar increments a day every 24 hours.. anyone has any idea wut am i supposed to do.. wut I thought abt is that we know the Frequency= 1/Time period.. so if I say : 24hrs * 3600 seconds =86400 .. so the frequency i need in order the calendar turns after 24 hrs is 1/86400 am I right ?? Please I need help ASAP .. :) thnx4 Replies
Then as suggested by others, previous posts, you can divide down MHz to Hz. Then use it has global clock. At Hz frequency, PLL would not work.
It's a pure VHDL .. usually i used to divide the clock to make it faster.. but now i need it slower ..
Is this pure 100% HDL project OR Nios II project?
a cascade of counters, something like this:
process -- clked on 27MHz if Hz_count /= 27000000-1 then Hz_count <= Hz_count +1; else Hz_count <= 0; if seconds_count /= 59 then seconds_count <= seconds_count + 1; else seconds_count <= 0; if minutes_count /= 59 then minutes_count <= minutes_count + 1; else minute_count <= 0; if hours_count /= 23 then hours_count <= hours_count + 1; else hours_count <= 0; if days_count /= final_day then days_count <= days_count + 1; else days_count <= 1; end if; end if; end if; end if; end if;
