9 years agoInterfacing with Arduino
Hi all, I'm trying to take input from an Arduino Uno R3 and process it on the FPGA. I have a Cyclone V GX board which comes with an Arduino expansion header, but I'm not sure what the best way...
9 years ago1. check the voltage levels,do you need a converter?
2. check no outputs connect to outputs 3. how many pins are available, is that enough? 4. if not enough pins is a uart or other serial periph. available? 5. if not using uart etc, how do you synchronise the data? these are the first things to consider.
