8 years agoInterfacing to epcs64 from fpga
Hello, I am new to FPGAs and it is my first post here. We have developed a custom EP4SGX70 based board. FPGA Configuration is done using JTAG On the board we have EPCS64 which I am try...
8 years agoHello Again,
I think I made small progress I have noticed the option in ASMI Parallel "Disable dedicated Active Serial interface" which makes my ASMI block explicitly route out the SPCS64 'SPI' signals So I routed those signals out to my top level and I have specified constrains in my qsf file to their actual pin location. One of the assignment is asmi_dataout to Pin_P26 Now the actual issue is that I get Error (176310): Can't place multiple pins assigned to pin location Pin_P26 (IOPAD_X0_Y44_N62) Info (176311): Pin asmi_dataout is assigned to pin location Pin_P26 (IOPAD_X0_Y44_N62) Info (176311): Pin ~ALTERA_DATA0~ is assigned to pin location Pin_P26 (IOPAD_X0_Y44_N62) If seems a dedicated pin ALTERA_DATA0 is already assigned to Pin_P26. I have tried all I could in: Device and Pin Options -> Configuration/"Dual Purpose Pins" but this error stays constant at my Fitter stage. The only thing I find in my qsf file about DATA0 is set_global_assignment -name RESERVE_DATA0_AFTER_CONFIGURATION "COMPILER CONFIGURED" which OI tried to comment but this line is always updated as per my settings in the "Dual Purpose Pins" If I disable the assignment asmi_dataout to Pin_P26 just to give it a try things become even more interesting to me Error (169094): Can't place pin asmi_dclk at location AM3 (PAD_256) because that location is a dedicated programming pin location Error (169094): Can't place pin asmi_scein at location AM2 (PAD_257) because that location is a dedicated programming pin location Error (169094): Can't place pin asmi_sdoin at location AM1 (PAD_258) because that location is a dedicated programming pin location So my other 3 assignment fails as well. Can I use the programming pins ASDO, NCSO, DCLK and DATA0 in user mode for my EP4SGX70? What I want is to use the EPCS64 FLASH for user data and not for FPGA configuration at all. It is interesting that if I don't enable "Disable dedicated Active Serial interface" in the ASMI IP the compilation is fine. I am getting out of ideas. How to solve this? Thank you Dimitar
