8 years agointerfacing to epcq256 through fpga
Hello, I've posted this before but I'm trying to interfacing to the epcq256 via the fpga in order to store a counter on the epcq. I'm using the ASMI parallel core in order to transfer data to a...
8 years agohello, just wanted to say thank you for the help and that I have it figured out now. As it turns out, I did need to hold the wren active-high while the write mode took place. Also on my dev board there are mode select (MSEL) pins which I had in active serial x4 mode but when I changed it to FPPx8 mode it worked.
thanks again for the help, Alex
