8 years agointerfacing to epcq256 through fpga
Hello, I've posted this before but I'm trying to interfacing to the epcq256 via the fpga in order to store a counter on the epcq. I'm using the ASMI parallel core in order to transfer data to a...
8 years agoSorry - indeed that makes much more sense...
Re-read the description of the 'wren' port: --- Quote Start --- Active-high port that allows write and erase operations to be performed as long as it stays asserted. --- Quote End --- Keep it asserted for the duration of the operations it's required for. You're only asserting it for a single clock cycle. Cheers, Alex
