8 years agointerfacing to epcq256 through fpga
Hello, I've posted this before but I'm trying to interfacing to the epcq256 via the fpga in order to store a counter on the epcq. I'm using the ASMI parallel core in order to transfer data to a...
8 years agoHi,
Which specific operation are you executing and seeing this issue (busy high issue)? Did you reset the IP for at least 2 clock cycle before executing any operation? I think you need to provide more information on the operation sequence (such as read, erase, write etc) in your project design to access the EPCQ256. It would be better to provide screen shots of the Signal Tap on each operation steps. Regards, nyusof (This message was posted on behalf of Intel Corporation)
